Creates a user key.
key_name | Specifies the name of the public key. |
key | Specifies the key. Note: The key cannot have any spaces in it. |
subject | Specifies the subject. |
comment | Specifies the comment (an optional field). |
N/A.
This command is used to enter, or cut and paste, your public key. You can also enter the public key into the switch by using the SCP or SFTP client that is connected to the switch.
This command was first available in ExtremeXOS 12.0.
